Old 23rd June 2013, 06:40 PM
I'd go for either H&R or Eibach hubcentric spacers. They are superb quality and you won't need to buy more wheel bolts as most of them bolt to your hub then you use your normal wheel bolts to bolts the wheels on.
With 8.5" wheels I would go for 20mm spacers per side at the rear and 15mm per side at the front which will space things out nicely
linky to hubcentric spacer site
