Originally Posted by PsYcHe
Not sure what's causing the clicking unless there's something silly going on with the climate unit.
I am slightly puzzled as to where they got the shorting bar if there was a relay in there before as the bar would be missing (or is that not your picture?)
The relay should have 5 connections on the bottom, that may make a difference as most have only 4 as they are simply on/off where the solar roof one switches between two power sources.
Originally Posted by HPsauce
It's IT's picture from earlier in the thread - relay socket taken from a pre-wired earlier car with no solar panel (and no relay), so the bar is shorting it out.
Sorry not a piccy of my car, one i stole from earlier. Just using it to explain where my original relay eneded up. I pulled the board out and realised that i had the relay missing after looking at IT's piccy
I have bought another relay to replace it. I didn't know at the time what the number was untill it arrived i just asked for a solar roof relay. So when it turned up and i went to the car i realised i had a 203 but in the position that 382 takes up in that photo (whatever that is for).
So pushed my new (secondhand) 203 in the empty space and, nothing.
When it did work the moment i pulled the key out the ignition i could hear the fan start up and even varying blower as clouds went over.
I only noticed the clicking when i went to get fuel, i haddn't put any of the passenger side back, as soon as i started to roll forward click, click, click, and clicked faster the quicker i went, reversed back and the same, stopped pulled the relay out and no clicking.
