Thread: I'm back!
Old 24th July 2013, 08:51 AM
Depends on the kind of garage that did the work to date - if a main dealer they probably went for the 'well that doesn't work as intended so we'll change it for a new one and see if it fixes it' rather than following a logical fault finding exercise that'd probably cost more in labour than they could justify charging.
Potentially a day with a decent specialist would sort it if they can work through from first principles. To confirm the switch is duff you need to know which pin on the back should be doing what and at what time in the starting/running cycle
