Old 12th August 2013, 04:10 PM
I've fancied an S8 a few times, but the performance delta just isn't huge enough to offset the increased fuel costs, and that the spec I want in my budget would be ceramic brakes, and they'd be approaching a change by the time I could afford the car.
Test drive a 4.2TDi.. then imagine it with 50 more horses and a pile more torque with a remap and it's not so much slower that you'd notice most of the time. Given the equipment options, you'd be surprised how much diesel your money would buy over the S8.
Not that I'm biased
Couldnt agree more...... Theres the staus of having the 'S8', and the Lamborghini connection, and the noise I'm sure, but the problem is that unless you genuinely have pound notes to burn, or do next to no miles whatsoever then the 4.2 Tdi makes more sense every which way.
And then theres range..... I get no less than 600 miles to a tank, and usually more, and that makes a real difference when you're always in a rush everywhere
The Q7 is having its DPF removed and a remap this week, so we'll see how that 4.2 Tdi behaves after a tweak and if its worthwhile I might just have to see about treating the A8 to one too...
