thanks! I just called Cordel, he can look at it next week, but says it is a high probability one of the front struts has failed. And that I would need to replace both sides if doing one.
Is that true? If one side fails is it a safety issue to not replace the other side too?
He said he would do a diagnosis for $100 if I wanted to then do the work myself - depending on what the diagnosis is.
I have a tow service who brings flatbeds, but getting on and off without wrecking the nose will be tricky...
