View Single Post
Old 22nd August 2013, 06:57 PM
I had similar with a Citroen specialist I used to use - would drop the car to them on a Friday to be picked up the following Friday and they would NEVER touch it before the Friday morning, despite needing to check out some issues, potentially order parts etc, do big jobs. Eventually stopped using them as I found somewhere more reliable closer to home.
If it helps at all my only slightly out of date copy of Etka suggests they retail at £473+VAT (£567) so I hope they're a good bit cheaper than that if he wants to retain your good will
Might be worth a call to local TPS to see what they would charge?
I work for Citroen UK, think I get bits at cost + 10% if you ever need them, Adrian.
