Thread: Spacer options
View Single Post
Old 6th September 2013, 07:54 AM
If you bolt the spacer to the hub with the 5 wheel bolts, how much sideways movement do you get on the spacer bolt holes when they're not fully done up? If the answer is any at all then I suspect the only option to get a completely vibration free fit is to balance the wheels on the car, but don't know any places that can do that - you do hear of people having it done though.
Personally once you've found the correct spacing I would definitely be looking for one with the spigot ring fitting
The spacers were able to move fractionally on the loosely done up bolts but it was so slight and I thought that, being aluminium, the eccentric mass wouldnt cause a problem...... it obviously did.
