Old 9th September 2013, 04:30 PM
Don't order bracket for now. Try to install with screws in the standard recess behind cluster as OEM place for receiver may be difficult to reach. You will only need two screws from my list to install receiver in the recess behind cluster. Or you can use double sided foam tape with some cable tires to fix it anywhere under dash when knee panel is removed.
