Old 9th September 2013, 07:49 PM
Do you always disconnect battery when doing these little jobs or not worry about it? I don't appear to have the radio code for my rns-e so bit nervous of unplugging!
Will have a look in elsawin for trim removal instructions and see what I can see. Might be just as easy to pull the cluster. It must've been out to do the rns-e wiring so hopefully not too tricky to get out!
Will need to get it coded as don't have vcds
