Originally Posted by The_Laird
....or incontinence?
3 beers is too many while driving 1, the empty bottles make a lot of clanking when cornering and 2, well unless you have a Oasis bottle or similar with a larger opening you get blowback.
Originally Posted by Adrian E
Mine did this when I first got it - was going to clear the drains but then ended up pressure washing the underside and it cleared whatever was blocking the drain
I have to be a bit carefull it's only rust thats holding my front subframe together.
I'll have a look at the roof drains on Friday to see if i can find a blockage.
