Running issues again
Last night driving back from work and engine missing started again, instantly thinking fuel pump as the exact same issues as before. Obviously laptop was flat so dumped the car at work. Just plugged it in and i have a few faults.
16684 multi cyl missfire, 89 cyl 5 miss, 90 cly 6 miss & 91 cyl 7 miss
I realise that these cyl's are all on the left hand bank
17913
Can anyone help?
I'm showing 1/2 tank of juice but i'm going to put a couple of jerry cans in at lunch and see if it makes any difference as i have had similar before at just below 1/4 tank causing the same problems. However i get issues with engine start block by immo and i never changed the wire just put up with it, i get over it by just turning the ignition on and off and back on untill the immo light goes out, lastnight i took a long time (worst it's been for a long time) and took about 5 mins to get it to go out. I noticed that when it did fire up my fuel had dropped from 1/2 to half way between 1/4 and 1/2 and then when running all be it really lumpy it started to rise again, i now have 1/2 a tank.
