Old 25th September 2013, 12:41 PM
Ignition amps were common failings on the ABZ's.
There are 2 of them, 4 cylinders each.
Drivers side of the engine bay under some plastic trim just past the bulkhead iirc.
Swap them over, see if the fault moves (if it'll crank at all)
You should hear clicks from the injectors, but its a very quiet click, and generally they dont fail, or at least not enough at once to stop it firing....
