Old 25th September 2013, 01:21 PM
A little update on this, the problem reappeared twice yesterday evening near the start of a short run. Just significant lack of power for a few seconds, no other symptoms.
I replaced the coolant temperature sensor (it was suspect) a while back and have been running exclusively on Shell V-Power Nitro+ for some time and all has been fine.
Checked the codes today and the 01119 Gear Recognition Signal (intermittent) was there again, but nothing else. It's about 3 months since I last checked.
The Ross-Tech Wiki just says 01119 is a note and to refer to the TCM/J217 for detailed codes. I presume that means 02 Transmission in VCDS or is it something more detailed I need to get at?
A document I found online also says that intermittent codes will clear quickly, so do I need to stop ASAP after an "event" and plug the laptop in?
Malfunctions that are stored in DTC Memory as sporadic malfunctions are automatically erased after 1,000 km (600 miles) or 20 hours.
Though neither 1000km or 20 hours have elapsed since it misbehaved yesterday, so maybe the 01119 is not connected to the lack of power?
