Old 27th September 2013, 10:37 AM
You can now use cluster's adaptation channel 19 to switch on lower bit to make cluster aware of the receiver and then drive for some time without knee panel testing reception with procedure I provided. If you're happy with reception where car stays during night you're fine.
Thanks, I just had a look with VCDS and channel 19 is currently set to 30000. Does that mean I set it to 30001?
I just had a look where the clips fit and only 3 of the 5 will be reuseable on my car, sadly. The two by the steering cowl and bottom right near the bonnet release. The other two were not secured anyway.
The other two clips should go onto plastic mounting bits of trim, but these have been broken off (not by me!) so there is nowhere for the metal clips to slide over. Fixing them is going to be tricky, so I'll live with it as it is for now.
Both of the unsecured screws are jammed into the metal clips, so I think someone probably used a power tool on them, got them cross-threaded and so rotated and ripped the clips through the plastic mountings, throwing away the plastic bits that presumably fell out.
