Old 30th September 2013, 12:12 PM
Stevie Stevie is offline
I'm interested
Also that headlight is cheap
It's arrived. Pretty well scratched... Seen a guy who changed the front of the glass by putting the lamp in an oven for 5 minutes at 200c. It was for a 7 series E39, but the process looked right. To put it back in just do the same thing again. It must be right as I can't see how you could service anything in the lamp, unless you had freakishly small alien hands.
Plan right now is to see how I get on with the windscreen repair kit. if it looks good I'll run with that. if not, I'll have a go at polishing the spare headlight and removing it from the light body. If that works ok, I'll have a go at swapping the glass.
