Old 2nd October 2013, 09:38 AM
If all synch sessions at 3am, 4am and 5am ended with failure cluster makes additional synch sessions after each trip. Definition of trip from cluster point of view: ignition goes on, then cluster receives some speed signal, ignition goes off, key is removed and cluster displays go to sleep mode by timeout. Immediately after that synch session starts.
* If all synch sessions ended with failure for the last 3 days cluster goes back to normal quartz clock mode.
Very useful analysis, thanks.
My initial (forced) sync was on Sunday morning around 10:30am, since then the receiver has been sitting in the "knee hole" and the radio indicator has remained on.
As there have been 3 "overnights" since then I'm assuming it's getting a signal OK there.
I'll give it a few more days then tuck it away.
