Old 5th October 2013, 06:07 PM
Those clips are horrible to get back in, as I remember from my PF S8, but there are only 5 to do. I might just use Velcro strips glued in place.
Edit: No Velcro. The trick was just to get the alignment right, not easy lying on your back in a stupid uncomfortable position.
You need to see the fixing hole clearly through the hole in the material (sometimes 2 layers) before carefully pushing the "split" component in smoothly and squarely to its full depth. Then the locking "mushroom" goes in without much pressure and finally press the whole thing in firmly.
