Old 1st February 2009, 01:40 PM
Yup, I agree ^^^^^^^ - Remove the bypass loom withthe two red connectors, and instead plug the blue/yellow/green connector straight into the Nav unit. This will almost certainly bring your CD changer back to life.
The nokia is a hands free kit, but I suspect the computer-lan type RJ45 connector either does, or did go to a cradle. Unless you want to preserve the nokia functionality, then it could be removed if you trace the various wires and remove them too....
