Old 7th October 2013, 08:04 PM
What are you going to do with screws in alu brackets?
OK, found those pictures on the forum in Russia. They are from a PF car.
FL has a different seat back and screws are accessible from inside as I said earlier, so no problem at all.
My hatch is from an FL car and I fitted it into an FL car so I have all the bits.
If you were working on an PF car you probably would have to take the seat out, both to remove and reinstall.
BUT because the FL also has extra bolts to secure the seat back, you need to cut round those too - I just sliced off 30mm at the top for a quick & easy solution.
(think I'm repeating myself a bit here..................)
