  #103
Old 16th October 2013, 04:54 PM
Mine should arrive any day now and, as I don't have a heated screen, I'm going to try the knee panel location, probably starting in that little recess at the back of the instrument cluster. I am, after all, higher up than you lot here in Scotland!
Hi Jim, just selotape it to that recess with knee panel off and try it with the quick procedure described above and then for 3 days. If can be fixed permanently in that recess with 2 screws (part number provided above). This will require releasing two front bolts behind two caps that hold cluster in place and moving cluster just an inch forward. No wires needs to be disconnected. This will create just enough space behind dashboard to fix the receiver with 2 screws in OEM recess.
