Thanks very much, that's EXACTLY what I needed to know.
I'll get my trusty multimeter out to check as well.  My labelling is rather different though, which is why I was
To be specific, the 8-connector block at the top, which is of most interest, has:
Top line: Earth, "Sun", S.Kont, TEL MUTE
Bottom: UB+, SAFE, K.BUS, GALA
The little aerial (what is that?) on the picture above is SAFE on my RNS-D which I believe is a permanent +12v to stop you re-entering the security code.
And what is K.BUS - anyone know?
By the way, the individual wires going into the CD unit are fairly accessible with the cable cover/clamp removed.
Colour codes on the CD Changer fly-lead seem different, but the plug is also fairly easy to open so identifying them by position should be easy. The plug is numbered and correctly "mirrors" that above.
EDIT: Found some info online which suggests your picture is of a Symphony radio label which is "slightly" different and doesn't require a separate "SAFE" wire.
RNS-D is like the attached picture:
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
