Old 20th October 2013, 09:19 PM
Congrats Amar, hope the coolant is a easy fix.
Make sure you charge your battery to full to see the heated windscreen in action. Sergey found out it uses around 1000 Watts, which from a 12V battery is close to 100Amps, so its module will not let it work if the battery is not near fully charged as its voltage will sag too much with such a high load.
