View Single Post
Old 21st October 2013, 10:12 AM
Norretal's Avatar
Norretal Norretal is offline
Adrian, did the new washer pump definitely solve your washer fluid level problem, or was it just coincidence and maybe a connection was remade properly when it was all fitted back together?
The reason I ask is that I had a washer pump replaced last year and it's all been fine until a couple of days ago when my fluid level warning light came on and I topped it up as normal. However, the level warning light has remained on, which is annoying but nothing more. The windscreen and headlamp washers are working fine and I'm not losing fluid through a leaking pipe or anything so I was just checking before I start investiagting further under the bonnet.
Thanks in advance, this was the only thread I could find with any reference to the problem I'm experiencing
Audi TT - 2015 - Ultra
