You need to remove just the faceplate. Then on my car I needed to add a bit of length to wiring loom so that two fog light looms reach new button position.
There are 5 wires in each loom. Basically cut the loom in the middle and solder in a about 15-20cm of new wire so that the loom becomes longer. Then wrap new extended loom with Certoplast and it will look stock and untouched.
