it most likely needs coding to your car.
If you have Bose and the car the headunit was removed from did not then the pre-outs will be disabled until coding.
Likewise
If you do not have Bose and the car the headunit was removed from did, then the speaker level outputs are disabled until it has been coded to say that Bose is not present.
Coding will need to be done with VCDS.
