Old 7th August 2009, 03:50 PM
CliveH's Avatar
CliveH CliveH is offline
Default All looks good
Sounds like you've done an excellent job
Yes, if the airbag wasn't wired up properly or it was replaced with the battery connected, then you would have the airbag warning light on.
and if, like me, the steering angle sensor (G85) wasn't properly lined up, the ABS and ESP lights would be on
