Old 16th November 2013, 06:54 PM
I assume you will still have shelf with TV tuner, mobile phone antenna amplifier and other stuff above it.
Nope, none of that at all.
I am installing a TV tuner, but it's a small aftermarket DVB-T box and will be going somewhere else, probably around the dashboard area.
And my phone is linked via Bluetooth through an XcarLink unit (which also has music on SD card and USB and can connect an Apple device).
I'd suggest getting BOSE kit for D2 and retrofit it.
I certainly miss Bose, but from what I've read that's a major (and expensive) mission that involves stripping out much of the interior and all the door linings.
a8parts may well be able to supply you a full bose wiring loom, but its still very much a whole interior out job to fit. Last time I did one, it took 12 hours end to end, with 2 people. It's doable for sure, but you gotta really want it
