Originally Posted by sutherland
I have perfect TV reception, but no FM. Have had the A8 in bits trying to find a fault in the antenna wiring, but nothing obvious.
VAG COM gives an 00856 Radio Antenna Open Circuit fault. Does this indicate an internal problem with the RNS unit itself rather than the antenna amplifier or antenna wiring?
Hi, it would be extremely rare for the RNS unit itself to be the cause of this fault, and indeed I personally doubt the rear antennas will be the cause either.
In our experience, we have seen a few cars with faulty FM, but perfect TV.
The 'interesting' thing is that they all use the same aerials on the rear screen.
They are fed through a diversity switcher which lives at the bottom of the D pillar trim, on the passenger side (UK).
To access it, you will need to the trim covering the D pillar.
You will see 4 aerials feeding into it, and a number of connections out. 4 of the outputs will go to your TV tuner in the boot. 2 other connections will supply the FM radio at the front of the car. There is a non-coax power connector too.
If i were you, I'd remove this unit and inspect the FM connections thoroughly. Typically, the tiny coax connections on it fail, and sometimes even break away from the board. It is probably possible with a little skill to resolder it back together though, which will save some expense.
Photo attached for reference....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
