Old 26th December 2013, 10:27 PM
Whats the part number on your original hub?
Another way you can narrow it down, is to look at your option codes on the boot sticker or in the service booklet. For example mine is 1ZL (Disc brakes, front), so I guess I can chose any of the housings that fit this code?
1 4D0407253 wheel bearing housing left front 82MM / PR-1LT,1LX
(1) 4D0407254 wheel bearing housing right front 82MM / PR-1LT,1LX
(1) 4D0407257AD wheel bearing housing / f. vehicles with wheel disc: left front 92MM 20" / PR-1LT,1LX
(1) 4D0407258AD wheel bearing housing / f. vehicles with wheel disc: right front 92MM 20" / PR-1LT,1LX
(1) 4D0407257R wheel bearing housing / F >> 4D-1-006 000* left front 82MM / AKF:1LX
(1) 4D0407258R wheel bearing housing / F >> 4D-1-006 000* right front 82MM / AKF:1LX
(1) 4D0407258AD wheel bearing housing / F 4D-1-006 001>>* right front 92MM / AKF:1LX
(1) 4D0407253A wheel bearing housing left front / PR-1ZL
(1) 4D0407254A wheel bearing housing right front / PR-1ZL
(1) 4D0407257T wheel bearing housing / f. vehicles with wheel disc: left front 92MM 20" / PR-1ZL
(1) 4D0407258T wheel bearing housing / f. vehicles with wheel disc: right front 92MM 20" / PR-1ZL
(1) 4D0407241J wheel bearing housing / with: / wheel hub / for special armoured vehicle left front /
(1) 4D0407242J wheel bearing housing / with: / wheel hub / for special armoured vehicle right front /
(1) 4D0407241P wheel bearing housing / with: / wheel hub / for special armoured vehicle / (for modified vehicles) left front /
(1) 4D0407242P wheel bearing housing / with: / wheel hub / for special armoured vehicle / (for modified vehicles) right front /
(1) 4D0407257AD wheel bearing housing / F 4D-1-006 001>>* left front 92MM / AKF:1LX
