>> im thinking to try and cover the whole relay box with maybe a plastic bag to prevent the water going onto the relays
If you do nothing with Botang's hole the water will get to rear seats area because floor is a bit inclined and water will accumulate there. If you wait -- you can have 5+ litres easily under rear passenger feet area (I'm not joking!) since there's a lot of foam under the carpet in the rear. Removing water from there is painful (seats out and carpet out job).
Fix the hole now. Don't think of covering relay box with a bag.
