Thread: Mirror Issues
Old 16th January 2014, 02:24 PM
Not at all, probably 5 minutes if you know what you're doing.
Lever out (carefully) the lower shell of the door pull with a trim tool. It will release easier at either the front or back edge first (not sure which, so try both).
Then push up the switch panel from below so that the outer edge lifts up first and swivels towards you (in the drivers seat) to unhook the lugs.
Disconnect all the plugs and take indoors to work on. You'll then see that the mirror switch is just held by two retractable toggles and a lug opposite them and can then be pushed out.
Obviously you can test it by just connecting the new unit directly to the wiring plug in the door without replacing the panel.
