Not at all, probably 5 minutes if you know what you're doing.
Lever out (carefully) the lower shell of the door pull with a trim tool. It will release easier at either the front or back edge first (not sure which, so try both).
Then push up the switch panel from below so that the outer edge lifts up first and swivels towards you (in the drivers seat) to unhook the lugs.
Disconnect all the plugs and take indoors to work on. You'll then see that the mirror switch is just held by two retractable toggles and a lug opposite them and can then be pushed out.
Obviously you can test it by just connecting the new unit directly to the wiring plug in the door without replacing the panel.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
