For the front trims, lever from the narrow rear edge - when you get it out you'll see the front edge is much larger so needs locating first when you refit
2 bolts to release the switch surround, then pry up as her HPs post
Releasing the switch itself is easy enough although 3 hands are useful! Flick the 2 plastic sprung clips and push out all at the same time
