The veteran guys on quattroworld say there is nothing in the rack to wear out. Its a rack-and pinion, there is nothing to play in there (unless somehow you tortured it to death and ground all the teeth down?). You either tighten using the adjustment bolt, or change the tie rod ends. Or check the 3 rack mounting bolts are tight. Why would you change the rack?
