Originally Posted by mannyo
Thanks for all the legwork you are doing for me.
Got my car back this evening, he took the compressor off again and checked it over and says its fine. No signs of leakage from any of the pipes, so I'll see how the suspension goes.
No problemo Manny, just give him a call tomorrow afternoon, ideally after 2 or 4pm.
Where would you get specs of how long should it take to raise and lower suspension to see if there is already a wear/leaks which would slow down the operation??
I assume there should be a leak detecting procedure do0ne by the dealer (like used by commercial gas engineers on gas installation or at least this type)
Or it will throw errors straight away as soon there is loss of pressure ???
