  #61
Old 31st January 2014, 09:58 PM
Looking at your logs I would say your compressor is good, looking through it I guess you were either changing the settings in mmi or you were running in automatic and went above the speed threshold were the car self lowers.
The way the system works the pressure reading is only true when the car is being lifted when the accumulator valve is open.
With that in mind the best test will be by doing the output tests i mentioned earlier as it is the only way you will get a max pressure reading.
Your log shows that the compressor quickly recovers the pressure when it switches on so your good.
