Old 12th February 2014, 01:31 PM
peanutmnm's Avatar
peanutmnm peanutmnm is offline
Ah thanks IT. I guess it's the non Bose system as there's no amp in the boot.
It's a little misleading as there are Bose stickers on the rear parcel shelf speakers.
I'm certainly not using the Sat-Nav any more so I suppose I'll just disconnect the speaker as you suggest. I was just wondering if anyone might have known which pin it was on the wiring loom or if there was a way to disable it via VCDS.
Cheers, Mike
