  #41
Old 13th February 2014, 08:48 PM
In a car with solar sunroof there is a hole in the tray for a sunroof wire.
Can I expect to have the same hole in the tray of a car without solar sunroof?
Your pic doesn't show Sergey - are you talking about the hole to retain the connector, or the one where the electrical wiring passes through from the contact to the underside of the panel?
This is how the wiring runs through when you've removed the upper rail:
