Thread: Botang's hole
Old 17th February 2014, 12:21 PM
I'm pretty sure that the first picture is the one that I've seen referred to as Botangs Hole, below outboard edge of the ECU box I think on RHD.
Did you have to pull the ECU box forwards to find and access Dezzys Hole? Or is it "just" taking off the cover across the base of the windscreen?
(Might investigate mine if its the latter and we ever get a fine day)
I can't see how the box is secured apart from 1 nut on a ali stud outside of the box at the front (that sheared off rather than undo)
Dezzy's / Guy's hole is easily found by taking the cover off ECU box and i took 2 ECU's out but left them connected to to the wires.
I don't understand why it wasn't pointed out before when Guy posted up his write up about it. Even Botang didn't say it's not the right hole
LINK
I'll have one more go at it failing that i'll pour concrete down there hopefully it'll find it's way down under the ECU box
