Old 26th February 2014, 12:56 AM
yrk2.7t yrk2.7t is offline
Originally Posted by Mugzee View Post
Looking at the ZF parts catalogue it doesn't seem as if there is one.
I'll top it up then.
Good catch there is not
You have to loosen the bolts on the one side where the diff is located and then without letting the front diff fall out pop the bottom of the cover out so the fluid can drain out.
Or I suppose you could also try to suction it out of the fill plug.
I like method #1
