Old 1st March 2014, 09:08 PM
Nollywood's Avatar
Default 2nd VCDS Log.
Sunday,23,February,2014,14:00:23:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 28 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 67 72 76 77
VIN: WAUZZZ4EX4N019359 Mileage: 246250km/153012miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0D0332330
Coding: 0011773
Shop #: WSC 00759 210 91871
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0110
Revision: 00000001 Serial number: 0029737
Coding: 0000001
Shop #: WSC 02312 823 51201
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0008597
Shop #: WSC 00759 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0332330
Coding: 0411648
Shop #: WSC 02311 785 00200
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
Shop #: WSC 02313 785 00200
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 300AE047529272
Coding: 0000000
Shop #: WSC 00000 000 00000
Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 13:55:56
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000035351
Coding: 1069137
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0123001
Shop #: WSC 02314 785 00200
Part No: 4E2 910 113 B
Component: Wischer WWS D3 H40 0400
Coding: 00000036
Shop #: WSC 02314
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02314
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 C
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D0000829
Coding: 0000403
Shop #: WSC 01221 210 182300
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 1400303C022DA2
Coding: FCFE7FDC2B7504
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1031965
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0411648
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158
Component: KLIMA-STG. FOND 015 0210
Revision: 00000014 Serial number: 00000000014873
Coding: 0000000
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0015510
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4063850
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 D HW: 4E0 919 887 C
Component: MNS ECE H43 0550
Revision: 00000000 Serial number: 305AF047553820
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000402700074
Coding: 0035984
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRMH01 0060
Coding: 0032622
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040401220055
Coding: 0004857
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0360
Revision: PROD_01 Serial number: 00000000201652
Coding: 0000027
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000032526
Coding: 0010101
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRMH01 0060
Coding: 0032622
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0560
Revision: 00000000 Serial number: 304BR047558890
Coding: 0000001
Address 57: TV Tuner Labels: 4E0-910-146.lbl
Part No SW: 4E0 910 146 E HW: 4E0 919 146
Component: TV analog TUNER H12 0270
Revision: 00000004 Serial number: 00000000006057
Coding: 0001003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000262164
Shop #: WSC 00976 210 16715
Part No: 000 915 105 AK
Component: von VA0 1401160348
Coding: 303030393135313035414B56413031343031313630333438
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRMH01 0060
Coding: 0032622
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 K HW: 4E0 035 753
Component: SDS 3502 UK H43 0600
Revision: 00000000 Serial number: 00000401120163
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRMH01 0060
Coding: 0032622
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 08730402100078
Coding: 0001008
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0770
Revision: 00000001 Serial number: 00000000000000
Coding: 0000004
End ---------------------------------------------------------------------
