Originally Posted by A8L
I have removed the MMI module with help off here - very simple and took 15 mins to have the unit indoors.
I guess the first thing to try, if it's that easy to remove, is to see if there's anyone near you who's prepared to let you remove theirs and try swapping them over (temporarily) as a test?
I'd also look at it very carefully to see if there's an obvious way to dismantle to look at the switches.
Items like that will probably have some complex onboard electronics that interpret the buttons/dials and then send digital signals down the connector.
Switches usually have some sort of spring/return/contact mechanism behind them which may be something as simple as a bit of moulded silicone rubber. If this is damaged or dislodged it can stop it working even if the actual microswitch is OK.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
