I think when in Automatic, it drops to Dynamic height at just over 80mph. I'm sure I read that when swatting up on the manual. Automatic mode is cr@p though in my opinion. You get the ride height of Comfort mode but with the 'comfort' of Dynamic!
The same as when in Dynamic and travelling just above 80mph, it drops down again (only a tiny bit though - 5mm if I remember correctly). Just trying cruising at a steady 85mph and after 10 or 20 seconds the down arrow on the MMI screen will illuminate (indicating that the air suspension is is lowering).
After you drop to 50mph for 10 or 20 seconds, it will revert back to the standard height for Dynamic or Automatic.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
