Old 14th March 2014, 08:19 AM
Couple of issues:
1 - The keyless unit isn't happy. Could just be faulty antennas, but the unit is prone to water damage if you've ever had any in the car, so it may be dodgy. Worth getting the codes cleared and see if they return if the keyless usually works.
2 - Footwell heater - They break.. A little over £100 to replace the unit + labour
3 - High pressure sensor - Get it checked, your aircon probably won't work properly without it.
4 - Alarm horn - They do go.. not too hard to replace.
5 - CP - Either needs Dealer to reset, or may go when re-coded properly and codes cleared.
