I've never seen a D3 run a completely clear scan, they like to log erroneous fault codes at the drop of a hat. For example my sunroof works perfectly, but it sometimes pops a fault into the roof electronics for no reason at all. Just seems to be the way of the D3, the sheer number of electronic systems leading to phantom faults.
its always recommended with the D3 to clear all the fault codes and then go for a drive, then scan again and see whats cropped up and assume that these are most likely current issues.
