Old 26th March 2014, 04:39 PM
£25 each? Surely that cannot be right. I bought one from dealer for AHC engine couple of years ago as I could not find one elsewhere and it was around £140.
Fuel pressure regulator for AHC is 4 bar which is highest VAG make I think. It could be lower on other engine codes and if so you could swap in one from AHC engine otherwise it will need to be aftermarket market one and you could get adjustable as well. If you increase pressure by much say to 5 bar or more you will most likely need beefier fuel pump as well.
