Old 27th March 2014, 04:23 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Removing and installing interior door lighting strip
Special tools and workshop equipment required
t Removal wedge -3409-
Removing
– Remove door trim → Rep. gr.70.
– Unplug electrical connectors -1- and -2-.
– Unscrew bolts -arrows- and detach door opener.
– Unplug electrical connector -1-.
– Carefully press lighting strip -2- out of door trim on back -arrow-.
– Use removal wedge -3409--item 1- to carefully prise lighting strip out of retaining clips.
Installing
Installation is carried out in the reverse order; note the following:
– Install door trim → Rep. gr.70.
ID:	7620   Click image for larger version
ID:	7621   Click image for larger version
ID:	7622   Click image for larger version
[center]
06 3.0TDI Quattro:
Options:
