Old 5th April 2014, 07:39 AM
Start with checking all the plugs, make sure they are correctly and fully plugged, check for water ingress/corrosion. Check wires for visual damage. Then move to swapping parts between cylinders-spark plugs, coils, injector one at the time and see if cylinder 1 misfire moves to another cylinder together with the part.
