OK, then this should help you at least a little.
PM me your address and I will send you (gift) a spare cable I've got.
It's not a Ross-Tech one, it's a VAG Commander Full, but at least you'll be able to read the DTCs.
I'm sure you'll be able to do more than that, but I never managed to explore this cable and software fully.
You can download software here:
http://www.resettools.com/vag_can_commander_5.1_full
AS far as I remember, you can't use it on a laptop which is connected to the internet, but software doesn't need install so you can keep it on a USB stick and all you will have to make sure is remember to switch off all the internet connections before plugging in the USB stick and running the software.
