Old 8th April 2014, 09:10 PM
Mmmm when I had all my electrics out of the boot I had the same issue as you report. I don't know what was in there that would cause that but check the fuses above the battery that feed the fuses on the passenger side in the cubby hole in the boot, also check the fuses on the little fuse board in the cubby too.
